A friend at work asked me to build him a gun cabinet. He wants raised panels on the sides and drawer fronts like the first pic below. He wants a two piece construction with bottom cabinet (2 drawers, 1 door) and top cabinet separate, like shown in the second pic below. He also wants the foot detail to be similar to the second pic. It will be sized for 10 long guns (7 rifles, 3 shotguns). Rough dimensions are 48W x 75H x 17D.
I don't have a raised panel or rail/stile set. He has offered to buy me one as part of the price but I have some concerns/questions. (He seemed to like the roundover rail/stile with an ogee raised panel.)
I would like to have raised panels with an edge profile on the rails/stiles but I want the joinery to be M&T. The rail/stile sets I've looked at online cut the profile on the rails so there is only 3/8 inch or so of "pseudo-tenon" at the rail ends. This can't be as strong as a M&T joint.
I guess the bottom line question is, how do I rout the stiles/rails to get the desired edge profile and still use M&T joints for strength? Do I have to use an appropriately sized roundover bit then use the TS (or straight bit) to cut the dados in the rails/stiles?
I am comfortable with the overall construction and hope to get a new tool out of the deal...a NICE new tool out of the deal!
Also, he has asked for construction in "oak". I gave him a price estimate for wood only for flat sawn red oak, then also gave him prices for cherry, walnut, QS white oak. He doesn't want cherry or walnut...most of his furniture is oak. I figured 400 dollars for flat sawn red oak, 655 dollars for QS oak. I also counted on yielding 2/3 of the purchased stock. Does that seem reasonable?
I have never worked with QS material (except when it got thrown into the mix accidentally) but wonder if it would be worth using to avoid any potential problems with warping/movement on the panels. Is this a valid concern? Is a good compromise to go with QS stock on the panels and flat sawn on the remainder?
I will admit that I have not had a problem with cupping/movement after assembly using KD red oak but I would be sick if it happened on something so nice for a friend.
Any thoughts or suggestions are appreciated. Pics below.
Chuck
Chuck
