So I have this really nice Grizzly 2hp dust collector. Got the 4" black plastic tubing (can't afford the really nice metal kind) and ground wire. Accord to Grizzly, ground wire should run INSIDE the plastic tubing... ok so I did that. Didn't seem to have a problem until, I used some white pine to make a couple of benches. At some point between using the planner, or joiner things got really clogged (and I have a two stage separator). I pulled all the ground wire out and just ran it on the OUTSIDE... to make a long question short .... is it ok to just have ground wire wrapped around the outside???? (and yes the ground wire runs to a good ground)
