I am sure that some remember me asking about router plate inserts.
I also asked some questions to some of the members about building a router table.
Well this is what I have been up to.
I have the Ridgid TS3650. The OEM fence requires that that front and back be installed. I am also in a garage that is starting to run out of space. I need to be smart about any additons in tools.
Plus...I wanted a decent router table.
Well I have taken the concept from the Norm Table and built a table that is also an extension to the tablesaw.
In addition, the router table acts as a support for the rails and also a guide to keep them straight.
I used 1" angled steel to create a ledge to mount the melamine sheet onto the rails.
The top of the table itself has 2 sheets of 3/4 " plywood. I am not expecting any flex.
And I used to screws to run up through the sheets of plywood and into the melamine top to anchor the two together.
So..the router table is part of the TS and anchored in......BUT...if I need to take it out..or change the melamine, I only need to unscrew the screws.
Yes, you do see two switches....
The one on the front of the router table is for the table itself.
The one mounted on the side of the router table is for the vac system.
I am not done yet. Still got some trim, dust systems, plexi-door for the router, etc to install.
I am also trying to decide if I want doors or a drawer on the bottom.
I was unable to get a direct on shot with the camera..(space issue).
I think you will get the idea though.
I used Melamine for the top. I am not certain how that will work out though. Therefore, I set this up so that the top is interchangable.
Also..I finally figured out that the Rousseau lift was just a little more that the Woodpeck insert.
So it has that too.
I still have the full extension of my fence..(36")
And I clamp the router fence to the tablesaw fence for a secure and straight fit.
Oh yeah..I know..I need to clean the mess. Probably get to that on Sunday.
So it has that too.
