My grandfather gave me one just like that earlier this year and I restored it and it works great. You can use something to get the rust off like W-D 40, vinegar works well too and then sand a lot on the cast iron top and it will get there. Don't worry about getting it perfect, but it does need to be relatively flat. There are four screws under the infeed table that adjust it into parallel with the outfeed table, which does not move. Adjusting those four screws is a pain, but if the tables aren't co-planer then it's not going to work. If you need a new bel
My grandfather gave me one just like that earlier this year and I restored it and it works great. You can use something to get the rust off like W-D 40, vinegar works well too and then sand a lot on the cast iron top and it will get there. Don't worry about getting it perfect, but it does need to be relatively flat. There are four screws under the infeed table that adjust it into parallel with the outfeed table, which does not move. Adjusting those four screws is a pain, but if the tables aren't co-planer then it's not going to work. If you need a new belt for the motor then there are several good replacements and a bunch of youtube videos walking you through the whole process. I also took the time to paint it, but you don't have to.
