Re: Foyer Floor Damage NEED HELP~!
Do you think this will cost more than our $1000 deductible???
And how sure are you about the upper leak? I went upstairs and touched the wall all around where it is right about that area and there is no water damage or signs of it?
Matthew
A picture is worth a few thousand words. Call your insurance agent and get a roofing company out to find and fix the leak and a contractor to fix the floor and the wall. I imagine you've got a good mold growth going inside the sheetrock and beneath the subfloor in the foyer. If you can climb under there you should check it out with a screwdriver and make sure no rot has started.
Go ahead and caulk the door but the leak is not coming from there. That area is well protected from all but hurricanes.
Matthew
