I have built two free standing vanities. The idea is for them to look more like furniture than traditional built in vanities. Was shooting for a little Shaker influence. Not sure if I succeeded.
Oops this is suppose to be about finishing and I really do have a question, problem with the finish.
I used ash and I am now stuck with it. I thought I could finish it the way I have finished kitchen counter tops made from cherry and edge grain oak. Things are not working out so good.
The problem is the deep grain. I used ash because my wife wanted the vanities stained very dark and I could not bring myself to use a more expensive wood. Should have used poplar, to late now. I stained the wood, sealed the stain with 3 coats of wipe on poly and then started applying a marine varnish finish. Even thought the varnish is a satin finish it is much to bright. When I buffed out this varnish in the past it was not a problem. Now with the ash when I buff it out I am left with nice shinny streaks because of the grain. I have tried steel wool and still can not even the look of the finish.
I am thinking about coming back over the top with a wipe on satin finish. Even if this solves the way it looks am I losing my durability provided by the varnish. Is the only choice to sand out the tops and use a grain filler. If this is my only option you might as well give me some advice on using grain filler as I have never used it.
If anyone has had his problem in the past and found a way to handle it I sure would appreciate your advice.
