I have to change the way photos uploaded probably just for a few minutes. This is necessary as fault isolation step.
No there is another issue. The error 500 is gone as long as the upload size is less than around 22 MB. But then depending on complicated conditions, the Photopost processing may fail with a memory out error.
I didn't get to work on the last part of this, because an upstairs toilet overflowed and it started raining a bit in the kitchen below.:gar-Cr
So what you are saying, Steve, is that there is a relationship between memory overflows and toilets? Or is it a relationship between memory leaks and toilets? :eusa_thin
In the meantime, you may want to watch out for links to Garbage Collection -- we don't want to know what happens when that fails too.
Kidding aside, it must be a whopper of a memory leak to be exhausting memory at a mere 22MB.
