I've replaced the top from the my first kitchen table I made a year go. Wasn't the best idea for that to be my first project ever but hey I learned plenty. Now I made the new top out of black walnut and put on my finish. Here's the finish schedule I used.
2 coats of garnet shellac ~1.5# cut (spray)
2 coats of blonde shellac with some dark walnut transtint (sprayed)
4 coats of target finishes waterbase glossy poly
1 coat of waterbase satin poly.
I was using oil based poly before (arm-r-seal) but couldn't but have wiping smudges everywhere when I used the satin for the last coat and I stupidly sat it outside to try to spray since I was having no luck and the sun took care of "stripping" off the poly.
Anyway here's my real problem. I'm afraid the poly doesn't have enough heat resistance as I noticed one spot where some hot liquid must have hit it and burned through to the glossy poly underneath. I also noticed today the finish would turn cloudy white when warm plate was on it (like pancakes etc) but discoloration went away as it cooled back off but I'm worried that's just a warning sign. Soooooo would an oil base poly have been better? I was going to use Rock Hard Varnish or maybe even waterlox but wanted to see how this poly would hold up since I have some and haven't used it.
If I decide to go with one of the short oil varnishes would I need to strip completely? Seemed like they wanted bare wood and I liked the color with the shellac so I just went poly :dontknow:. Soo I take it wouldn't be advisable to use Waterlox or Rock hard with shellac underneath?
