Figuring band saw blade length
dancam
Dan
I just got my e-mail newletter from Wood Mag and they had the following free tip for measuring blade length on a band saw. It sure beats tying a string around the wheels.
Dan C.
How do you figure the length for a band saw that doesn't have a blade to measure from?
If you lost your band saw owner's manual and don't have a blade to measure from, or if you've added riser blocks, put this simple math formula to work to determine your tool's blade length:
Blade length = (2xA) + (3.14xB)
Key:
A= distance in inches between band saw wheel centers when the upper wheel is midway in its adjustment range
B= bandsaw wheel diameter
Badabing
Nice! a little high school math, how nice it must be to be able to remember those types of formulas :rolf:
Thanks for the info Dan. It will definitely come in handy when I get a riser block for my BS!
If you don't have a calculator handy, you also could take a string (something like Mason's line that doesn't stretch) and wrap it tightly around both wheels as it was the blade. The lay it out and measure the distance.
JimmyC
Jimmy
Dan,
I like the way of measuring you suggest, not to sound stupid, but where would you measure the top wheel at; Either the bottom of the tension adjustment or the middle of the tension adjustment.
Thanks,
Jimmy:)
Dan C.
Key:
dancam
Dan
Jimmy,
There was a picture that came w/the tip but for some reason (most likely operator error) I can't seem to paste the picture in the post.
The picture shows the "A" measurment to be from from the center of each wheel hub. I would assume that the blade tension spring would be set normal.
Dan C.
jeff...
I just buy them 13' 2" and they always seem to fit, no fancy math required :-D
Jeff, Have you tried some 158 inch blades? I think they will also work. (Too good to pass up.) Happy sawing. Bruce
