Sold Festool TS 55 REQ Track Saw & MFT/3 Table System - Complete Professional Kit! $1000 for EVERYTHING!
Kirsti K
Kirsti
You know what's here and what it's worth!
Posting it here first for $1000 for everything! Will be posting it on Facebook tomorrow for $1200.
It will go to first to pay and pick up in Cameron NC! (Near Cameron Elementary)
What is included in the bundle:
Festool MFT/3 Multifunction Table
with the full set of original accessories.
Main Unit: Festool MFT/3 (Standard Model, not the "Basic" version).
Festool TS 55 REQ-Plus Plunge Cut Track Saw with Systainer
Key Accessories Included:
  • FS 1080/2 Guide Rail: The 42" (1080mm) rail used for track saw cuts.
  • MFT/3 Angle Stop (Protractor): The swivel unit for making angled cuts.
  • Fence Rail: The long aluminum extrusion used for material support.
  • Support & Swivel Units: The brackets that hold the guide rail to the table.
  • Adjustable Stop: The black sliding block on the fence for repeat cuts.
Festool Parallel Guide Set (Metric).
  • The Main Parallel Guides (FS-PA): These are the two long aluminum rails with the green knobs and the integrated metric scales (reading up to 650mm). They attach to the ends of a Festool Guide Rail (track).
  • The Parallel Guide Extensions (FS-PA-VL): These are the two shorter, curved "wishbone" style pieces. They attach to the main guides to allow for very narrow rip cuts (down to 1mm), where the saw would otherwise be sitting on the main guides themselves.
  • Small Stops: You also have the adjustable flip-stops (green levers) that slide along the main rails to set your cut width.
2 New In Box (NIB) Festool saw blades
Additional Festool Guide Rails
used for their track saw and router systems.Both rails are the standard versions (not the hole-drilled "LR 32" versions), which are highly sought after for precision cutting.
  • Festool FS 1400/2 (Shorter Rail) Length: 55 inches (1400 mm).
  • Festool FS 1900/2 (Longer Rail) Length: 75 inches (1900 mm). (needs repair on back)
I have a few additional photos I can share on request.
EricT
Eric
Good Morning. Will you accept payment now for pickup on Saturday? I can't make it there during the week but this would be a nice upgrade to my fairly new shop. I would just have to trust that everything is in good, working order.
