Ever Wonder What that Wood Was ?
You know, when you are in a big box store and they have this furniture that you look at and Wonder What is that Wood ?
I do, Every time I see some the grain is odd to me eye. Well, maybe my suspicion is confirmed.
At work they took down a African Tulip tree. If you ever come to Hawaii, they are the trees with the Orange Flower. Common here along with Albizia trees. Both from Africa. Both are considered weed trees here, mostly cause they grow quick and grow everywhere.
Anyway, African Tulip, is part of the Tupelo class of trees (Nyssa). But this stuff is light. I cut some last fall and finally it dried and I table sawed some up to see how it looks.
One piece is unfinished, one is with linseed oil and shellac, and the last is special walnut with shellac. The amber one looks just like that cheapo furniture right down to the grain. Well fun experiment. Another thing, this wood is super light almost to Balsa wood light. Weird stuff.
ScottM
Wonder how it would work on a scroll saw. Does it tend to crack and splinter?
Yep, I've seen that same wood on cheap furniture, and some of those glue-ups at the big box stores. Thanks for posting that.
  • Like
Reactions: Oka
FYI, it's not a Nyssa species (tupelo, etc). The botanical name is Spathodea campanulata.
The wood is not widely available and it's not planted on tree farms for a sustainable harvest. I doubt that it's widely used for anything.
Nonetheless, thanks for posting about it.
O
OK I stand corrected, one other thing about this tree it is the dustiest wood I have ever cut. It makes real fine dust had to wear a dust mask just to make a few cuts. Also, What we consider sustainable harvesting is not the same as other countries who consider sustainable harvesting as clear cutting and then replanting. Either way most of these typical non merchantable trees are often used by other countries because they are so cheap. They apply a surface hardener to it and it gives a better finish but, it is still lower quality wood.
