End grain table: how to stabilize checks?
eyekode
Salem
About 5 years ago a friend gave me a disk cut from a tree he had taken down. This weekend I got around to flattening it.
There are some checks in it, but they don't go all the way through. I was debating how to stabilize them. I could do butterflies. But was wondering if just epoxy would be sufficient?
I believe the table will live on my covered porch when done. So it will be exposed to humidity swings. But it is going to be a rustic piece and doesn't have to look perfect. Just has to hold my beer when I need a free hand :)
TIA!
Salem
robliles
I have used epoxy to stabilize checks but never in a slab like you have. I injected the epoxy as deep as I could in the check and then clamped it together as much as I could. Good luck!
eyekode
Salem
Thanks guys. I will start with epoxy and see if I need more drastic steps. I like how butterflies look in long grain slabs but not sure they will look great in this project anyway.
red
Papa Red
Red
I would fill the cracks with epoxy either clear or colored and do the butterflies. I think it would all tie together nicely.
Red
eyekode
Salem
Some progress: I filled the checks with epoxy and coffee grounds. Then I turned some legs, drilled some through holes and test fit:
The top is 4" thick and the holes are 2" wide. I drilled them over 3 days time with a forstner bit. I drilled 1/2" at a time, vacuumed the shavings and walked away to let the bit cool.
Today I made some wedges:
Also made some stretchers and glued up!
Driving those wedges was pretty satisfying!
Finish sanding the top will be "fun".
Still haven't decided on a finish for sure but am leaning toward spar urathene as it will live on my covered porch.
It is nice to be back in the shop!
Salem
Yes - Working with wood is really satisfying. I also work alot with metal, very different, fun, fascinating but, not like wood.
