Dust collection for Bosch 1250DEVS
mike_wood
Has anyone worked out dust collection to a Fein for the 1250? Apparently the adapter sold by Bosch does not work.
If tool manufacturers are concerned about user's health it sure does not show up in ease of hooking up dust collection.
Thanks.
T
toolferone
User not found
First off, welcome to the best woodworking fourm on the planet. I tried doing a quick search trying to find out what size the outlet is on the Bosch. The Fein vac has a rubber sleeve that works on a lot of tools to fit between the hose and the tool. If that does not work then I would take the Bosch adaptor with me to the borg and try to find a piece of rubber hose that might work to connect the 2.
Make sure you going to the "who we are fourm" and introduce yourself.
mike_wood
mike_wood
I should have said I have tried PVC fittings, rubber hoses (drain hose for a washing machine was close) (Lowes/HD) and about everything else I can think of. The rubber sleeve for the Fein, which I use often, does not work in this case. The outlet is 19mm thus the problem fitting. As I mentioned other woodworkers (on another forum) said the adapter to 1 1/2" does not fit & not waste my money.
I was hopeful someone has worked this out. This sander generates too much dust not to have it attaced to a dust collector.
Thanks for your advice.
Ray Martin
Ray
Hi Mike,
Let me just echo Tom's comment... Welcome!! I'll also second the suggestion that you post a note in the Who We Are forum to introduce yourself. Tell us about the kinds of woodworking you like to do or the projects you take on. How long have you been involved with wood? What kind of a shop do you have?
We also love to see photos of work done by our members. So, select Help Desk - Request a Photo Album from the floating task bar on the left of the screen.
I'm looking forward to hearing more about you and getting to know a bit about your woodworking. Again, welcome to the NCWW.
Ray
