Drilling holes into tile?
Henry W
HenryW
Are masonry drill bits the right choice for drilling holes into tile? or are there specialty tile bits?
I will be mounting a grab bar in a bathtub area.
shawn
shawn
You can buy carbide bits designed for tile at lowes or ace. They typically come in 1/4, 3/8, and 1/2 inch. They don't require a hammer drill but use a low rpm sow you don't burn the bit.
185314
FlyingRon
Board of Directors, Webmaster
Ron
The one above will work, but they also make small diamond abrasive coring bits that work nicely as well.
Phil S
Board of Directors, President
Phil Soper
Use the diamond coring bits. I have a full set if you want to borrow
Henry W
HenryW
thanks, I picked a set up like Shawn showed, and they worked great.
Thanks for the generous offer Phil - I think these will be useful additions to my own tool set.
John - What are pled bits? "pled bits for porcelain tile"
A caveat to doing this - If you are mounting a grab bar, you should secure it into a stud or some other solid backing. Ceramic tile and whatever backer board it may be adhered to can fail, and a bathtub grab bar is NOT a place you want a failure (think concussions, hemorrhages, skull fractures, Michael A DeMayo sending you a subpoena). Secure it well.
Coring bit for porcelain the carbide pointed tip for ceramic or other ovened tile. Brick and or cement type types the regular masonary bits.
I use pretty much only the 1st 2. The diamond abrasive bits work will but do not hold up as well as they claim, but they are good as well
