I am still in the final planning stages with my next project, a wide walnut dresser. I plan to use vertical grain solid walnut sides joined to the top and bottom carcass with half blind dovetails. I was originally planning to use plywood for the top and bottom carcass since it is quick and is not shown on the final piece. I am concerned however that the plywood will not move seasonally with the walnut that it is dovetailed into and that I will have joint failure or splitting of the walnut.
The depth of the dresser (width of the walnut) is going to be between 20" - 21" so the question is: should I go forward with the plywood plan or substitute something cheap like poplar that will move with the walnut seasonally?
Thanks for the help.
