Lorraine,
With my jig (PC4212), you have to plan on drawer width's etc, to be in 1/4" increments in order to get a uniform 1/2 pin on each end. Also. When setting up your pin board, make sure that you accurately measure the half pin size on the template (I use a 6" rule calibrated to 1/64" increments.) at each end before you cut. Or, try it out on some scrap - same thickness and width. And, like Monty said, make sure that your boards are nice a tight and square to the side stop on the jig.
I find that with my PC4212, I have to make a couple of test cuts to get it right. It can be frustrating, I know!:BangHead:
Good Luck,
