We bought a 50 year old, under insulated house last year because it is on a large lake. It is also brick with nice landscaping and a layout we can work with. But when the temperature goes below freezing, the heat pump cannot heat the house to 70 degrees. When it was in the teens it wouldn't get to 60 degrees in the great room, the main issue. The great room is almost 25x25 with 16.5 foot ceiling. The old heat pump has heat strips but just isn't large enough. I've had a HVAC guy look at it and they say it is functioning fine, just to small to keep up. I added insulation in the attic which helped but didn't solve the problem. I need to insulate the floor but I also need to change the bathrooms so I am waiting until I get the bathrooms done.
The other reason to change the fireplace is my wife doesn't like the smell of wood smoke. The fireplace draws well so there isn't much odor but she still doesn't like it.
So I am about ready to buy a direct vent fireplace that will fit into the existing fireplace in the great room. There is a local shop that will do the installation (if I pay, of course). It will have to be propane, we don't have gas at this house. The propane company is ready and willing to put in either a 120 gallon tank or two 100 gallon tanks. They check the 120, I have to switch between 100 gallon tanks and call for another to be dropped off if we go that way.
I'm looking for experience with direct vent fireplaces, especially if you happened to use propane. Can I get meaningful help with heating? Will cost be OK? Would you get a 120 gallon or two 100 gallon tanks? Other thoughts?
