Dewalt 735 planer infeed outfeed set up
Westpacx3
What is the concensus on inffed and out feed table set up.
100 percent flat end to end
Or
Even where the tables meet the bed and raised on the outboard ends.
I was pretty well set up until I took the Machine in to have dewalt check something but now I get snipe on every board. All I did was take off the tables and carry the machine in
They addressed my issue without touching the machine. Its never been an issue since I first adjusted it. Problem is that I don't remember how I had it. Pretty sure it was the 2nd option above but having done that, it's still off.
Can anybody help with this.
tvrgeek
It may depend on how thick a board you are running. If running a 3 inch bit of Cherry several feet long, that raise may actually be pushing up on the head. I would go flat or only a little bit. Depends on how long your outfeeds are, stock or extended. And droop will most likely cause snipe.
pop-pop
Man with many vises
I have a 734 but IIRC the tables are set to 1/8” high at the in and out edges.
Actually, I have a 733 Type 1. After RTFM, here’s the relevant stuff.
jfynyson
Jeremy
When I brought the machine (735x) home (purchased used from this site) and immediately replaced the cutterhead with a helical then I used the penny trick (if you know what that one is) initially and had virtually zero snipe but after using it for a while I believe the table have sagged so next time I use it I'll be redoing them to see if they're still a penny high and adjust up from there
Westpacx3
Westpacx3
Thanks, I am pretty sure the penny trick is what I did and was the hack I was looking for. I'll be testing it out this weekend.
ChemE75
Tom
I started getting only a slight outfeed snipe, suspect outfeed extension sagged a bit since initial setup. I definitely did not raise outer edge very much, 1/8” at most. I need to revisit the adjustments. But for expediency I found using an old 4’ piece of laminate flooring as a crude sled for boards up to about 6” or so works great. I don’t use too much over 4’. But for longer, or wide boards with some warp, I got a used sled from a member here with some adjustable supports, works well with no snipe.
Westpacx3
Westpacx3
At present I just have a little on the infeed but I have a piece of cabinet grade plywood set to the side for a sled..it just bothers me that it was 100 perfect for so long and now it's out.
Thanks
ChemE75
Tom
Thanks
Any possibility something built up an a roller, or worn? Have had mine long enough.
Bill Winter
Dollar
I use a planer sled (melamine shelf) on top of in/outfeed tables and planer base. I set a small (1/4" per foot) rise at the ends and seems to be best for me. Note: I usually surface smaller (<2.5' boards).
I do this as well. I still get a bit of snipe, especially on the infeed. I have finally come to the realization this machine will "snipper" (the nickname I gave my planer), no matter what I do.
Bill Winter
Dollar
Any chance the tables got swapped around...infeed to outfeed and vice-versa.
This is a planer and therefore it only has one table. It is not adjustable and sits directly under the cutter head. To adjust depth-of-cut one lowers/raises the cutter head/motor, which rides on 4 posts.
Henry W
Henry
Yes there is a primary planer bed as you describe.
But there are also 'add-on' infeed and outfeed tables that help support stock in the process.
