The saw head moves smoothly back and forth and all of the head adjustments move. Some of the pins that index the head are stiff and gummed up from sitting. The hand crank that moves the head up and down is stiff but it does move the head. There is some light surface rust on the main shaft so that is likely causing the stiffness. The fence adjustments blocks are not turning. I put a little Kroil on it but haven’t messed with the saw much more than that.
It’s 115/230v and I have not even looked to see what it is already wired for. I am assuming 230v based on the plug, but haven’t wanted to plug it in and try it without verifying.
I bought it to restore but don’t have the time to make that happen.
