Delmhorst Moisture Meter - $50 (North Raleigh)
NCTurner
Gary
Date: 2009-12-26, 2:23PM EST
Reply to: sale-sx5c9-1525219364@craigslist.org [Errors when replying to ads?]
Digital display with separate scales for wood, plaster/concrete, and gypsum. Measures wood moisture content over the range of 6-40%. Reference scale provides relative moisture readings in non-wood materials. Averages up to 50 accumulated readings. Adjustable, audible set point alerts you when a pre-selected % moisture content has been reached. Green, yellow and red LEDs provide at a glance indication of moisture conditions. One of the industry favorites for testing EIFS (Exterior Insulated Finish System).
Features:
• Resistance technology recognized as the most accurate method for measuring moisture
• Easy one-hand operation
• Proven microcontroller circuit
• One-year warranty
• Can be used with Standard, Tapped or Deep Wall Probe
• 9V battery and Carrying Case included
• Three scales:
Wood Scale -6% to 40% moisture range. Use for flooring and building material such as wood studs, floor joists, subfloors
Reference Scale - reads from 0 to 100 on a relative basis. Use on non-wood materials such as concrete, plaster, and insulation
Gypsum Scale - 0.2% to 50% moisture range. Use on sheetrock
• Averages up to 50 accumulated readings
• Set-point alerts when pre-selected moisture content is reached
• Connector to attach any available electrode for deep penetration
Applications:
• Wood
• Plaster
• Concrete
• Gypsum
• Paint
• EIFS
Spec Summary:
• 6%-40% moisture range on wood
• 0.2%-6% moisture range on gypsum
• 0 to 100 relative scale for all other non-wood materials
• Size: 7.5"x3"x1.75"
• Weight: 1 lb. 3 oz.
• Battery: 9V alkaline
  • it's NOT ok to contact this poster with services or other commercial interests
Already sold...I should have been quicker.
Thanks for posting!
