Dado's with a Router?
Canuck
Hi All,
Need some advice. I have not yet invested in a dado set for my TS and continue to depend on my using my router for cutting dado's. My latest undertaking is a cabinet to house my new compressor and bench grinder and I attempted to use the router for the shelf dado's. I am using 3/4" plywood that of course is not exactly 3/4" - just a wee bit less, hense my joint is sloppy when using a 3/4" straight bit in the router. Do you know of a straight router bit that I could use in this application? (I seem to recall seeing something in a magizine by CMT (i think), but am not sure if that is what I need and where to get one. (I don't have the patence to use a 1/2" bit and nudge my way to the correct width of dado.)
I would appreciate any suggestions that you could send my way.
Thanks,
D L Ames
D L Ames
I have the same set by Freud, they seem to work pretty good. I wish I could have gotten them with 1/2" shanks though.
D L
User not found
Canuk,
I have a 9-piece set of bits from Woodline America that give you both undersize and oversize bits along with 1/4", 1/2" and 3/4" straight bits on 1/2" diameter shafts. They are one sale right now for $39 on their website at http://www.woodline.com/scripts/prodView.asp?idproduct=591. I bought mine at the Charlotte WW Show last year and they work well. You can also get a 1/4" shank set for $49. While not the quality of the Freud set, they are carbide and do a good job (I always score my dado lines and tape them on plywood to avoid chipout.) I also use a 50" Tru-Grip Clamp 'n Tool Guide to guide the cut. BTW, when you do buy a dado blade for your TS, I recommend the Freud SD506 (6") or SD508 (8"). They are sweet!:cool:
Steve D
Member
Steve DeWeese
You can make a simple set of jigs that will let you get it exactly right without "sneaking up". Below is a quick sketch:
Hopefully this will make sense with the sketch. Above is the board to receive the dado and the two jigs made from scrap. Take a straight piece of wood 3/4" x 2" x more than the length of your dado. Glue and screw that to a piece of plywood or masonite 1/4" x 6" x the length of board #1. Clamp that overhanging a bench. Put a 1/2" straight bit in your router and extend it more than 1/4". Run the router along the fence on top of the 1/4" piece. That will trim the jig to the exact width from the base of your router to the outside edge of the bit. Do the same on the second jig. Clamp jig #1 along the top layout line of your dado and then space jig #2 using a piece of your plywood in between the two jigs. Clamp jig 2 in place, remove the "spacer" and run the router (set to the depth of your dado plus the thickness of the base of the jig (1/4") along both jig fences. You will have an exact fit with a flat bottom and very simple layout. If this doesn't make sense, I'll try and post more sketches to clear up any questions.
User not found
Steve's method is a really good one and one that's very easy to implement -- but remember that you need to make a different set of these jigs if you're going to use a 3/8" bit for an undersized 1/2" dado, because the router-to-bit distance changes. But of course, all of us have plenty of scrap!!:lol:
Monty
Monty
Here, take a look at this, too. Same idea, just uses a bearing guided bit. Either way, the idea is to rout the groove exactly the same width as the thickness of the shelf.
Hope this helps.
You do realize, of course... now that you've received all this help, you have to show us the finished project when you're done! :cool:
Joe Scharle
This is a jig I made from Shopnotes plans. They have a short video on their site. It works great. I use a 3/8 spiral bit no matter what size groove I'm cutting.
Found the url
http://www.shopnotes.com/main/sn76-toc.html
D L Ames
D L Ames
Joe, does that work with a bushing guide in the router base or a bit with a pilot bearing like Insom posted?
D L
Charles M
Charles
D L
We are coming out with a 1/2" shank set very soon. Item number will be 89-650. Should be available within about 2 months.
Charles M
Freud America, Inc.
Charles M
Charles
The sets are nice to have but you can also get an individual bit for 3/4" plywood. Freud item number for the 1/2" shank version is 16-116 and 1/4" shank is 16-103.
Charles M
Freud America, Inc.
D L Ames
D L Ames
Charles M
Freud America, Inc.
Charles, unfortunately I already have a set with 1/4" shanks and don't use them enough to justify buying another set. Unless of course you want to help me trade up maybe.:lol:
So far. I like all of the Freud products I have used to date but find it frustrating that often times items have to be back-ordered. I am still waiting to get one of the new box-joint blades and some shaper cutters.
D L
Charles M
Charles
D L,
The SBOX8 Box Joint Set has been wildly popular and we have had difficulty keeping up with production. There are dealers who have them in stock. Kiligspor's Woodworking Shops have been pretty good at keeping them. Other than this item (and some other newly released items) I am not aware of B/O issues. What items are you having trouble finding?
Charles M
Freud America, Inc.
Joe Scharle
D L, actually neither. Just run the router base up against the 2 fences, back and forth. The hardboard gages are for visually setting the dado width. Someone else showed a diagram of the same thing using clamps. This one is self clamping. You could make these jigs any length you want, but I settled for a 40" length. Dado/rabbet both sides of a bookcase, for example, then rip it in half. If you ever this way, I'll show you.
Steve D
Member
Steve DeWeese
The jig version using a bearing bit is another good solution except that it has more limitations with dado depth because you have to maintain bearing contact with the guide fence. Dedicated bits are another option but they still end up with problems if the plywood is "out of spec", not that it ever happens with Chinese plywood or anything.:mrgreen:
The drawback to the base guided system is that you need to maintain contact with the same side of the base if it is not centered on the router.
D L Ames
D L Ames
Thanks for the clarification Joe. Do you remember what issue that jig was in?
D L
