I have not done one Kent but it looks pretty straight forward. From the online parts manuals, It appears the cutter head (probably with blades removed is designed to simply slide out one side or the other. Thats the reason for the oversized bearing housings on the ends. Each appears to have 4 bolts. Sure, youll have to remove one or more of the drive chain sprockets as well. You may have to install the inserts after you install the cutterhead due to diametral clearances of the cutter head and housing as well , I dont know. And of course replace the bearings while youre in there, I imagine theyre off the shelf stock bearings also. Good luck!.
