Crosscut sled runners from laminated hardwood flooring
Brogan
I'm building a large crosscut sled so I can make the panel lids for my bench seat.
I have boxes of hardwood laminated flooring available and when I cut a piece to width, it was the perfect thickness (depth) for the miter slot and slides extremely smoothly, so I figured it would make good runners.
I know that UHMW and HDPE are the go to materials at the moment but has anyone tried hardwood laminated plywood?
It looks like it would do a decent job and being plywood should be dimensionally stable.
For the record, it's maple with a satin finish.
JohnW
That should work just fine. One thing ill mention, laminated flooring can be very hard on your blade. Dulls them quickly. DAMHIKT. But as runners, they should work.
Brogan
I wasn't aware of that so thanks.
I should only need to make a few feet of cuts so hopefully it won't be too bad.
What give laminate it's exceptional wear factor is aluminum oxide in the finish. You say what is aluminum oxide - think sandpaper. That's why it kills blades.
Originally Posted by Fishbucket
Rub some wax on it, just be careful not to shoot it off into the shop wall...
Methinks he doth speak from experience....... :eek:
sawman101
Bruce Swanson
Better the shop wall than your spleen, as one budding lady woodworker experienced.:saw:
