Cross half lap joint with a mortise and tenon
NOTW
Notw
I don't think that the issue is whether it will support the weight of you or your table top but rather the side-to-side racking that can occur with lots of hand planing from end to end.
Maybe I am not reading this correctly, but I don't hand plane on my dining table, typically.
Everything is together now and am feeling no racking when i push on either side so hopefully all is well. All goes well i should be able to get it painted this weekend and the top attached. :)
NOTW
Notw
Ok finally finished the base, made the top and the bench several years ago. The table top and bench top are both solid walnut.
Graywolf
Board of Directors, President
Richard
The table and bench turned out great, thanks for sharing!
AAAndrew
Andrew
Looks great. And your original design, with a slightly smaller tenon that was wedged, is a classic design that goes back centuries, and would have worked just fine. You could have also used a tusked tenon to make a knock-down version and that works as well.
it's all good.
