This might be a stupid question but since I know less about electricity than I do brain surgery, I though I'd ask here. Is there any reason I could / should not install a quick disconnect in the wire that runs from the motor on my contractor's saw to the switch? In anticipation of rolling my saw out of the middle of my garage for those extended periods of non-use (yes, the honey-do list does not always involve cutting wood :cry: ), I'd like remove the motor and push it up against the wall. The motor is very simple to remove, except for removing the cover and detaching the wires. I though I could cut the wire and install a grounded male and female plug to make it even simpler.
Thanks!
Jeremy
Thanks!
Jeremy
