I need some advice about buying a miter saw and a blade, there are a lot to choose from and I want a quality one that doesn't cost $600. I'm sure some of it depends on what kind of wood I'll be cutting but I'll probably be cutting softwoods and hardwoods for making outdoor furniture, birdhouses etc. When I was looking at the reviews left on some that I found from Lowes and Home Depot, it became apparent that I most likely will have to buy a finer tooth blade (IE: 86,94) so it leaves a cleaner cut on the ends and doesn't splinter the wood. I know it needs to be carbide tipped so that's out of the question but I'm also wondering if I should get a sliding bar to make things easier than flipping a 12" board to cut it all the way through (although it probably won't be a common thing). I also want a single bevel for the angular cuts that I might need to make. I found this one (https://www.homedepot.com/p/Ryobi-15-Amp-12-in-Sliding-Miter-Saw-with-Laser-TSS120L/205673791) on Home Depot's website and it seems like a great deal for being $199, but I would probably just need to upgrade the blade. Any advice is appreciated.
