I am making a chess board and have some design concerns involving glue-up. The board will be made of 2 or 2.5 inch squares. It will have a thin beaded on top frame and then a wider frame about 2 inches on all 4 sides. Question is concerned about glueing the squares. No matter how you look at it, there has to be some edge glueing on opposite sides of the squares. To strengthen the whole board, I thought about putting a support under the board. A flat surface onto which the whole board will be glued. Not aure what to glue those together with - Titebond, Contact cement, poly???????? Anybody got suggestions or any pther ideas?
