T
toolferone
User not found
In an effort to kid proof the family room I needed to make a new CD rack with doors to keep little fingers out. It is not fine furniture. I used plywood and pocket hole joinery. I sprayed a clear water based poly acrylic finish on it . Each of the first 10 shelves will hold about 100 CD's that's 1000, The bottom 2 shelves I left tall enough for DVD's as I am running out of room on the DVD rack.
Well it is mounted in place. I have 3 screws running through the back into studs. It is solid. I am not happy with the doors. I knew they might not close flat. I will have to install some kind of catch to hold them tight against the frame.The most important thing is the LOML is happy!!
