Thanks I will take you up on it at some pointyes, I built my shop with attached garage in 2013. My shop is 24' x 36'. I'm an engineer so I'm fluent with CAD. I already had most of my floor standing tools so I drew up a pretty detailed plan including electrical. I put 120v outlets every 4' and a 220v outlet at every other 120v location. My 120v outlets are on 4 separate circuits number 1 through 4. As you walk around my shop, they go 1, 2, 3, 4, then repeat. That way if I need to large tools plugged in, they will be plugged in to say, outlets 2 and 3, so separate circuits. Also, prior to pouring the concrete floor, I installed 4" PVC pipe under the concrete with stub up locations where I wanted dust collection. So one location has 4 stubs together at the dust collector and the other ends are distributed around the shop floor. Also, in the center area of the shop floor I installed a 120V outlet in the floor. Oh, and go for 10' ceilings min. Don't go shorter! You'll regret that decision! If you're going to be doing any spray finishing, I'd think about a dedicated spraying room with the proper ventilation. Don't put up drywall on the walls, ceiling is fine. I put up OSB and painted it white. Some sort of plywood is good because you can hang anything anywhere! Any other questions, just let me know and I can DM you my phone number and we can talk... I see you're in Clayton, that's a bit of a ride but if you get up to Chapel Hill, you're welcome to stop by and see what I did in my shop.
What???As I looked around fo an alternative style(non windsor) many people encouraged my to build a ladder back chair with good intentions and no experience sitting on one. Ladder back chairs are the most uncomfortable chairs to sit in for any length of time. I found out the hard way after building a few and donating all of them. After teaching myself to turn the legs with all the details, I was drawn to the continuous arm style of chair design. This had the most challenging compound bending and it stretched my patience to the limit. l digress a moment. My early bendings were along simple lines and I had no mentor to question about details so went out in the woods and cut down a nice hickory tree for the bending day. Great .. it went well for me. Then the first set back came along. You can not get a drill bit through that stuff. More kindling.
I learned not to use hickory for the bendings or anything needing to be drilled again. So I fell into the world of Red/White oak for bending. As I was learning about building, I learned that I am a person who likes to slouch in a chair when I sit down and most people do too.
I learned the chair height that fits me: 18" at the front and 17 1/4" at the rear of the seat. This seems small but it counts in the end. I learned many other tiny bits that make your chair comfortable and not just pretty. Without being too critical, I can not sit in a Mike Dunbar chair but I love to sit in a chair built by Curtis Buchanan in Tennessee. Curtis has perfected his chairs over a 40 year span and it feels good.
I'm guessing Dan thought he was in a different thread, or starting a new one???What???
