Brax Corner Clamps
LeftyTom
Tom
What is the collective wisdom on these?
tvrgeek
Not tried those in particular, but any molded piece will have the release angle if not machines, so the never seem to clamp right. I have a box of corner clamps I don't use.
They do look handy maybe for holding things together while drilling or nailing. Maybe need just a slight bit of file work. Cheap enough to get a bunch of them. About a dozen or more maybe?
It looks like they only work on 5/8 to maybe 2 inch. Not thinner. They don't say.
tvrgeek
Looks like the same thing on Amazon for a lot less. So cheap, I may try. Yea, bought 2 of the $16 set. Seems like at least two clones. The $16 set looks better than the $11 set. Thinking of them as a third hand, not really a clamp.
LeftyTom
Tom
That was what I was thinking.
You can do the same with a ratchet strap and blocks 1/2 way between the corners to stand off the strap and focus the energy @ the corners. If you have "touchy" or soft corners then use a piece a bent cardboard to protect @ the corners. It will work as well.
LeftyTom
Tom
I imagine some issues with access if I am nailing or screwing (other than pocket hole).
tvrgeek
You can do it with a length of rope and a pencil, but these look nifty in being spring loaded to just hold things in position. They are not high force and not a substitute for rope, web, band, X, and a dozen other clamps that apply pressure. They should come by tomorrow night so sometime next week I make another little shelf in my shop and I can give them a try.
I have a set of these and tbh I only use them when doing a pix frame because the strap is narrow and they are a bit of a hassle. Here is what I do more often on bigger stuff. Also here is a Colin Knect video showing him doing something similar.
Strap vise
tvrgeek
Got my sets today. Look handy. Won't know until I try them. The center arrow slides so they can be used on boards of unequal thickness, rabbets, dados etc.
mpeele
michael
I have all ways been disappointed with miter clamps, or maybe I'm just a klutz. I always need 3 hands to use one. These might make my others easier to use.
I want to try the bangood "woodpecker-like" versions that use clamps, but thinking that will not work for small boxes???
