Bow clamp clamping cauls
Bowclamp clamping cauls reviewed
A while back someone created a thread about Bowclamps. There was a little discussion about them, but the general consensus was that nobody had tried them to give a reliable opinion about them. A reply was posted to that thread by Craig Feuerzeig of Zig Industries, the creator and maker of the Bowclamp system. He offered a set of the clamping cauls to be tested and reviewed by a member of NCwoodworker. D L Ames, took on the task, but due to a very busy work schedule has been unable to make the time to give them a good testing for review. He handed the set off to me to test and give y'all my thoughts and opinions about them. And they follow:
I have to admit that I was a little skeptical about the Bowclamp system. Not about the technique or method of using clamping cauls as it is a time proven method of distributing clamping pressure across a large area. Nor that they were well made items. But about the whole idea of buying curved pieces of wood for between $22-32 a set.
Well, I picked them up from D L on Saturday, and gave them a work over today. My first impression of the cauls as I removed them from the box was that they were definitely hand made, not by a CNC or any other automated process. You could see the tooling marks, a little burn from a router or shaper, and some slight chip-out from shaping. None of these thing affected the usability of the cauls, it just proved that Craig is a one man operation, and made each on himself.
Right off the bat I noticed that each set of cauls had their own unique curvature, definitely not random. I wanted to see if they would bow like they were designed to do so they could provide even pressure across the entire work piece.
Here's a shot of the cauls without clamps showing the curvature:
And with clamps applied closing up the gaps to a straight line:
After doing that I decided to put them to use in a panel glue up. I was making a cat bed, (as something to make that would require the use of the cauls). First I milled up three pieces of Lacewood that were to be the “headboard” of the bed. Normally I would use 3 or 4 Bessy clamps for this glue-up.
Here's a shot of the panels and cauls before clamping:
And after, showing very even (somewhat excessive for illustration purposes) glue squeeze out across the entire joint:
The cauls applied excellent pressure even though only two F-style clamps were being utilized.
The only draw back I found in this application was that I need to make 1/2” spacers to lift the panel so that it was in the center of the caul face to provide parallel pressure.
The next application I tried was a quick lamination of some Red Oak 5/4 stock to make the legs for the bed. Seeing as the panel was still drying in one set of the cauls I had to use my standard method of clamping for one and the cauls for the other.
Here's a 18” lamination using 3 Bessy clamps:
And here's a 26” lamination of the same stock using the 36” Bowclamp cauls:
Excellent glue squeeze out across the entire joint line:
The only issue I had during this application and others was the amount of screw travel to completely close the cauls. It takes almost the entire thread length of my standard F-style clamps...that's a lot of twisting.
I wish that I had a scientific method of testing how much pressure the cauls applied compared to a standard K-body style parallel jaw clamp. But I don't so I tried to break the joint after the glue had cured and the wood broke first...that's enough pressure in my book, it created a solid joint.
My overall impression of the Bowclamp caul system is that they are well designed, do what they are designed to do, and worth the money. A full set of 3 pairs of cauls 24”, 36” & 48” runs about $130. If you bought the wood to make them, about 6 BF of 8/4 hard Maple, you would spend around $36. Then factor in 3-4 hours milling, squaring, dimensioning, routing, cutting sanding and finishing, and you would come out better buying them. If you value your time like I do. I much rather be making something fun than some high tech bowed sticks.
And the savings goes even farther because instead of having a arsenal of expensive parallel jaw clamps you can use many less and cheaper F-style clamps. That is something that I found to be quite advantageous as I have many of the cheaper F-style clamps that I don't use very often due to their tendency to not stay parallel and to mar the work piece with their small area of surface contact.
My biggest complaint is that I don't have 2 sets of any of the sizes to be able to utilize them to help keep a panel glue up flat, something which I think that they would also excel in doing.
I would like to thank Craig for the opportunity to test out his product and commend him on taking something very simple and refining it to perfection for a reasonable cost.
Also thanks to D L for being to busy to test them out...I will find lots of use for them in my shop. If anyone would like to give them a test run themselves, I would be more than happy to let you give them a try providing you post your thoughts also.
Respectfully submitted,
Bowclamp
Toddler
Todd
Re: Bowclamp clamping cauls reviewed
Nice review DaveO.
and seriously. . . cat bed???
:rolf:
PS) PM me your address so I can send that nesting box plan.
cskipper
Cathy
Dave, thanks for a well written review. I think I was one of the first to mention these in thee original dissuasion, so I was especially interested in the results. It was also good to hear that DL is alive and well.
nelsone
Ed
Good Review Dave! I have also been skeptical about purchaing cauls. You did a good job on the cost breakdown.
DavidF
They sound like a good thing that I would find very useful. I have never been able to justify the high cost of K body clamps and their ilk, so I too have many "F" style clamps. I am going to be glueing up a lot of panels for the bedside cabs so perhaps I could borrow the 24" set??
Splinter
Dolan Brown
Dave, thanks for the detailed review. It helps to get a review from a know WW'er not just from the company's web site. I have to put them on my wish list.
Certainly, just let me know when you would need them, and I can drop them by Apex when I am in the area.
DavidF
Starting next week end! how about bringing them to the Apex lunch tomorrow? then everybody could see them and I could take them away:eusa_clap :eusa_clap
You bet, I'll write myself a note right now.
cpowell
Chuck
Very well-written, objective review, Dave.
I agree with you on the value of my time. And if you reckoned you could build a set in 3-4 hours that means it would likely take me a few days!! :lol:
Chuck
sapwood
Roger
Well thought out and thorough review Dave :icon_thum
Excellent point about not needing the big Besseys'. Their cost has limited me to mostly F-clamps. :roll:
Roger
Bowclamp
An amendment to my review. After visiting the SMC Bowclamp forum I realized that CNC technology (Shopbot as a matter of a fact) is used quite heavily in the production of the cauls. In addition to a very cool Drycleaner's conveyor system to automate the finishing process.
YouTube - bowclamp dipping mock-up
That doesn't detract from their usefullness, I just didn't want to be giving out incorrect information...even if it was only my erroneous impressions.
John Reeves
John Reeves
Thanks for the review Dave. It really helps when a trusted source comes forth.
Alan in Little Washington
Alan Schaffter
Do they have a durable and smooth enough finish so glue doesn't stick or can be easily scraped off? If I hadn't paid about 1/2 of what the Bow Clamps cost for my Besseys (during the Bessey frenzies of a few years) I'd think about buying a couple.
I still would like to see a test with a number of pressure strain gauges spaced along the joint. And also do the engineering and see what it costs to make my own- the curve should be easy to determine and draw with a computer and CAD program.
NCPete
Pete Davio
Hey, he is over 30!!! He can't be trusted! :lol:
I still would like to see a test with a number of pressure strain gages spaced along the joint. And also do the engineering and see what it costs to make my own- the curve should be easy to determine and draw with a computer and CAD program.
Alan, I e-mailed with Craig and asked about the pressure that they applied and if it was comparable to a clamp like a Bessey. He told me that in the design his aim was for 150 psi across the entire length of the caul. He also has some engineering type test with a material that is compressed and the measured with calipers to show that the pressure is even across the whole length.
They are waxed to prevent glue from sticking, but if I was to use them as cauls that would be in direct contact with a glue line (like keeping a panel flat) I would consider putting some packing tape over the faces just as an extra precaution.
I don't think that the design would be to hard to duplicate by following the original, but I still think that it would be more work than it's worth.
mkepke
I'm sorry, you lost me at:
"I was making a cat bed out of lacewood".
:lol:
-Mark
OK, let's call it a doll bed for my daughter, as I don't think that the cat will sleep in it without some adhesive persuasion. Although I did build a cat tree and they took to that like a fish to water.
I just needed something to make :oops: ...I can't just glue boards together for no reason, and the cat bed was my wifes suggestion. Wife wants = more shop time with less grief :-D :-D
:dontknow: :dontknow: :dontknow:
