Best option for a split?
atayal
Ashish
Experts, I’m just starting into woodworking. I’m more into just finishing for now, but slowly interested in getting into actual woodworking. One of the cypress piece I have, has a big crack in it. At the edge, the split is approx 1” wide. The piece itself is about 3” thick. What would be the best option to limit the splitting. Will a bow tie with remaining area filled with epoxy be sufficient? Would I need to put the bowties on both sides? What would be the recommended size & no of bow ties needed for this? Plan to finish it for a table top. Any recommendations would be highly appreciated.
chris_goris
Ashish, What you have here is the cookie drying out. When you have a complete slice as you do, the wood dries circumferentially, or along the circumference, it shrinks causing huge stresses in the wood an it ultimately fails and splits as its doing. The best thing to do is let dry for a while and let it do what its going to do before proceeding. Depending on the wood type , thickness and atmospheric conditions where this happens, this could take anywhere from a of couple months to a year or more. Once it reaches an equilibrium, you have options to fill with Epoxy and or add bowties. But until that piece stabilizes, you will probably spend a lot of time and effort only to have more cracks appear. Sorry I dont have better news! good luck.
