All of the leg assembly has come loose on this bench. It sees a lot of use at a university ministry centers.
It appears as though someone has tried a repair before and used polyurethane glue and used pocket hole screws to reinforce the leg to seat connection. The glue did nothing and scrapes off fairly easily. The pocket holes have held the legs to the seat and probably kept the entire thing from collapsing.
Would epoxy be a good choice for all of the joints? I have some 2 part epoxy leftover from replacing the tires on my band saw (Hi-speed cement). Or should I just use titebond 2/3?
Thank you for suggestions!
