Before COVID we made a house call to Dundalk, MD where our niece had just bought a home and needed some handyman tasks done. Whilst installing some plantation blinds, I needed a chisel to trim some window stops and had not brought one along. I bought this inexpensive Buck Bros. one at Lowe’s as a beater.
As time passed, I have reached for this chisel more and more frequently for “fine carpentry”. It is heavy enough to use as a small slick for paring a tenon or dado. It holds an edge quite well and doesn’t make you cringe when you hit a nail. And if you have to whack it hard it is tough enough. Not a beauty contest winner, but it feels good in my hand.
I try to keep it sharp and use my WorkSharp 3000 for that task. Using the chisel port, sand the primary bevel at 25 degrees up to 1000 grit. Then tilt the chisel port to 35 degrees and sand for just a second or two to add a tiny secondary bevel, Finally strop with green compound.
The plastic guard protects the edge when you throw the chisel into a tool tote for a household repair.
