Bearing replacement in Delta 20 inch bandsaw
Strom
Strom
I have a Delta Milwaukee 20 inch saw which has just started to sing the bad top bearing song.
Anybody replaced their bearings in the top wheel? What am I in for?
wndopdlr
wally
I have done a couple of smaller saws, but never a 20". I suspect they are similar. You will need a small assortment of hand tools and a set of snap ring pliers. Disassembly/reassembly is pretty straight forward. Suggest you consider Timken bearings once you get the # off your old bearings. Put the new bearings in the freezer overnight and they will go into the casting easier.
zdorsch
Zach
This one of the threads I have used as I rebuild my early 50’s Delta 20” band saw. The third page gives some great descriptions and pictures of the top bearing setup. Depending on the year of your saw, it should apply.
