Basic hand tool set?
Would you be able to build basic home furniture (very basic- think 1800s furniture) with this modern set of hand tools?
What else would you need?
Build or Purchase a Solid Wooden Workbench
Bench Dogs, Holdfasts
Jack Plane
Jointer Plane
Smoothing Plane
Block Plane
Router Plane
Rabbet Plane
2 Panel Saws: Rip and Cross Cut
Saw files, saw set, saw vise,
1-3 Back Saws
(1) a dovetail saw, with fine rip teeth, (2) a “carcass saw” (fine cross cut teeth), and (3) a larger tenon saw used for cutting deeper cuts, like tenon cheeks, along the grain (rip teeth)
Miter Box and Miter Saw
Coping Saw
Bench Chisel Set
Mortise Chisel
6-inch Combo Square
12 Inch Square
Try Square
Sliding Bevel
Miter gauge
2-3 Pair of Dividers
Marking Gauge/Mortise Gauge/panel gauge
Folding Rule and/or Tape Measure
Marking Knife
Sharpening Supplies
Wooden Joiner’s Mallet
a few Woodworking Clamps
Card Scraper
Brace and set of bits
Draw knife
Spokeshave
Screwdrivers
Hammer
Pencils
Misc. Supplies
Glue
Sandpaper
Nails
Screws
Hinges
Additional timber frame and lumber tools
Axe
Small ax/hatchet
Froe
Adz
Two man saw
Frame saw for resawing boards
Large slick
Framing chisels
Large square
Bark spud
tvrgeek
Larger than many a set. Maybe several profile router planes as the need arises? Consider a journeyman had to fit everything into one box he could carry.
I would think a small ADZ , wide blade Axe and longer bow-saw would be on a homestead.
Also a misery whip (2 man saw) we had one. Dad and I competed once with one- came in 11th out of 12 :D
gritz
Robert
You didn't state what the level of materials processing you are assuming the process would begin with.
My 1800s cabinet shows ax or hatchet chopping marks the plane did not remove on the beveled insides of flat paneled doors and on the back where it fits into the sides. Doors are pegged M&T. Drawers are dovetailed. One side is 7/8" thick and the other is 1.25" It also has a simple ogee trim piece at the top. The base skirt is not original.
Graywolf
Board of Directors, President
Richard
Definitely add a pencil, and maybe a few hollows and rounds to make moldings as needed. I have built several pieces with less. Any bench appliances could be built when or as needed. That said if I were to say land in the early 19th century, I’d want a hatchet and or an axe In that kit.
Steve Martin
Steve Martin
Would you be able to build basic home furniture (very basic- think frontier 1800s) with this set of tools? What else would you need? Build or Purchase a Solid Wooden Workbench Bench Dogs, Holdfasts Jack Plane Jointer Plane Smoothing Plane Block Plane Router Plane Rabbet Plane 2 Panel Saws: Rip and Cross Cut Saw files, saw set, saw vise, 1-3 Back Saws (1) a dovetail saw, with fine rip teeth, (2) a “carcass saw” (fine cross cut teeth), and (3) a larger tenon saw used for cutting deeper cuts, like tenon cheeks, along the grain (rip teeth) Miter Box and Miter Saw Coping Saw Bench Chisel Set Mortise Chisel 6-inch Combination Square Try Square Sliding Bevel 2-3 Pair of Dividers Marking Gauge/Miter Gauge Folding Rule and/or Tape Measure Marking Knife Sharpening Supplies Wooden Joiner’s Mallet a few Woodworking Clamps Card Scraper Brace and set of bits Draw knife Spokeshave Screwdrivers Hammer
With the thought that a lot of basic furniture was made from green wood, I would include a froe, froe maul, and hand ax, with the axe being the most important. However, if including the froe, then you are getting into the area where a shave horse of some type would also be of use. But, if you are looking for a "kit", you need to draw the line somewhere. When I built my "greenwood" stool, my hand ax got the lion's share of the work for splitting out and shaping the billets for the majority of the pieces.
If looking at early 1800's, you could eliminate the combination square. Although very useful, not absolutely "necessary". However, I would add an awl.
Edit: I see you have added the "timber tools" section, so "nevermind..." LOL
