Baseball bats
6 more to go…
Yessir, the client had the wood cut and kiln dried. The sawyer contacted me about the job then they came over and talked a bit. This one has a worm trace. They will be decorative with some commemorative laser engraving.
drw
Donn
Mike, great job...it looks very similar to those I used during my youth!
Looks great Mike. Did you turn it using a pattern, or totally freehand?
Turned freehand. I found a pattern to use but couldn’t get to a printer.
So, just trying to get them all sort of similar, they won’t be exactly alike.
ssmith
They look incredibly consistent. Other than the one you had to turn down, can't tell the difference. Obviously, lots of patient work on the lathe.
ssmith
While that's true it's not always that easy, at least for me.
I used to have a low-budget lathe. Found out the hard way that getting in too much of a hurry on some types of wood usually ends up with a trashed workpiece. Lesson learned! Aside from that, it was a lot of fun but the bearings finally went in the headstock, so the lathe went to the dump.
Nice work!
This is Ash.
It was harvested off the owners property in Danbury, NC.
Milled and kiln dried at The Tree Trunk Sawmill in Westfield, NC.
bob vaughan
Bob Vaughan
Nice work. Turning duplicates is always challenging.
The only petty little down side is when you get finished with the last one, there's a part of you that's sad now that you've got the process down right.
sawman101
Bruce Swanson
Hauled many log truck loads of prime ash logs to the Larimer And Norton ball bat mill in Russell PA years ago. Larimer And Norton is a division of Louisville Slugger--BB blanks of ash are milled there to be further processed by Louisville Slugger. The once vast stands of Ash trees are currently being decimated by the Emerald Ash Borer which burrows under the bark and girdles the tree killing it. Just another wonderful plant species being wiped out by invasive foreign pests.
Mike, what kind of finish will they have? Is there some sort of standard for bats like a varnish dip?
