Yesterday I got the WoodMizer fixed - had a loose drive belt - it was not any easy thing for me to figure out but it was cutting bad because when the blade was in the log the motor was spinning at 3750 RPM but because the drive belt was loose it was not putting enough power to the blade and causing a bad cut. Literally there could be a hundred different things wrong but after a call into wood mizer we narrowed it down to a hand full of things. Wood Mizer has the best customer service of any company I've ever had to deal with. If you own a mill - you gotta be a mechanic too.
