rickc
User not found
I built a "zero clearance" table for my bandsaw, and incorporated a scale on the top to use as the basis for a circle cutting jig. To use the jig, I had a base with a brad through it, to which I attached the stock I was going to cut. I would insert the brad point in a hole on the corresponding point of the scale, and go about business. Sounded good - BUT when using it this weekend, it bound my bandsaw blade. I was cutting pine, on a Delta 14", 1/2 hp saw with a 1/4" blade. Radius was 2 3/4". When I took the tock out and tried cutting freehand, it worked fine. Anyone have a jig that works for them?
