I'm looking for Baltic Birch for making jigs. A 2' x 4' x 3/4" sheet was $45 at Woodcraft, is there anywhere else to buy it from that might have more reasonable prices ?
TIA
I will split a sheet with you if you find some.
Jimmy, you sure that wasn't the Finnish Birch ply you were looking at at WC? It's usually quite a bit more than BB and I believe the only diff is it uses exterior rated glue, someone correct me if I've run off the rails on that. They usually have the Finnish separated from the Baltic, but most times they're mixed when I'm in there.
Also, you can get a BB rated 60"x60" sheet of 3/4" for about $49 plus tax at Wurth/Raleigh Hardwood. Unless of course Robert gives you tha hookup! :gar-La;
Brian.
Whatever happened to appleply the US made competitor to baltic birch?
