Thanks Mike. Never heard of it. What advantage, if any, is there over Linseed oil?I use organic flax seed oil on all my kitchen ware and baby rattles. It is food, so absolutely food grade and dries to a harder finish that can be built up to a gloss if desired.
Not suspiciously nor begrudgingly. Yeah, happy to show it is safe.Happily ?
I buy it in quart bottles, keep that in the kitchen refrigerator then use a small squeeze bottle from dollar store to apply the oil and refill as needed.I thought that flaxseed oil could easily go rancid and I don't have a refrigerator in the shop.
I have used pharmacy grade mineral oil and wax on rattles.
Worth noting for anyone new to this that this is the food safe mineral oil from the pharmacy, not the stuff found in the paint department.Mineral oil is all I would use. Perfectly safe, easy to apply and can be reapplied as required.
Mike-do you have any concerns about it going rancid on your utensils or does that problem go away once applied and cured? I am currently using BLOFlax seed and linseed are from the same plant. Flax seed oil is cold or expeller pressed without the use of any chemicals. Cold pressed is the most natural oil as the expeller press will generate some heat from the pressure levels used in the process.
Linseed oil is basically the same except chemicals are used to more fully extract all of the available oil from the seeds.
Linseed oil is not considered a food product even though some claim it is safe after a certain drying time.
When mothers ask me if my finish is safe I can honestly say yes, I would happily drink it.
