Assembly Table W/*PICS*
Alan in Little Washington
Alan Schaffter
My first big post with pictures:-D
I am just about done with an assembly table for my shop. It's not motorized like DavidF's table but the height is adjustable using a leg assembly idea I borrowed from a colonial candle stand. The table is 4' X 7' X 4" thick.
It uses a beam box (torsion box) top made from 1/2" MDF grid and top/bottom skins and 3/4" MDF sides. Unlike the one David Marks built on his show where he cut short pieces for grid laterals to fit between the longitudinals, I made a large box joint-like jig. I cut 1/2" wide, 1 1/2" deep dados in the grid material so the lateral and longitudinal grid pieces would interlock.
Cutting grid material:
Close-up of grid cutting set-up (for 7" grid):
Completed grid pieces:
Grid test fit:
Assembling the grid- just glue, no brads:
Here is the table upside down with skins glued on and the recently installed legs. Leg tenons fit in reinforced pockets in the bottom of the table. The two-part legs extend via a ratcheting assembly. To increase the height of the table I just lift it up, one end at a time. I still need to add a release cable to the ratchet arms so I can lower the table.
Close-up of ratcheting leg assembly. In addition to setting the height, the ratchet assembly draws the leg sections tightly together.:
The legs also have mating dovetails to keep both halves aligned.
Close-up of Table at low height (25"). The table is strong, rigid, and flat. I haven't put a straightedge on it so I don't know the actual tolerances. The table is not sagging- the apparent sag in this pic is caused by the wide angle lens. I still need to add oak edge trim and a laminate top.
Table at full height (37"):
Link to thread on finished table
Monty
Monty
That's a great solution for the adjustable leg design! It will be interesting to see how you do the release cable. Great job!!!
Ray Martin
Ray
Alan,
Nice table. Really nice. I really like the idea for the ratcheting legs. I just wish my workshop was big enough to fit a nice assembly table like yours.
Ray
kota62
Gary
Alan:
The term KISS comes to mind ;-)
Did you mark heights on the legs so you don't waste time running around to confirm the height in the heat of the moment
Hope it gives you years of un-noticed service...
Gary
Very well designed and executed. Did you come up with the leg adjustment idea yourself?
NCPete
Pete Davio
really great looking table! I will be dealing with stowable folding tables for the foreseeable future, as LOML would still like to be able to park her vehicle inside!
Canuck
Cool design Alan!!!:eusa_clap
How did you cut the "teeth" in the upper part of legs? Did you make some sort of router jig?
How much do you reckon it weighs? It sure looks substantial and sturdy!
Great Work!
woodguy1975
Nice job. It's an adjustable height assembly table revolution. :D We now have both DavidF and Alan adding adjustable assembly tables. Now Alan, where do the motors go. :) Gotta motorize it somehow. :rolf:
Mike Wilkins
Were you an engineer in a former life? This is one of the neatest/smartest concepts I have seen. Most tables for assembly purposes are only one height-low or at knee level. With this set-up you can adjust for the project, instead of having to conform to the floor or a table height.
Stay safe and watch those fingers.
User not found
Excellent design and superb execution. But you wouldn't catch me in a picture atop a table I build -- it wouldn't support my dainty frame...
Well done!
A
Alan Schaffter
kota62 said:
Alan:
Gary
Since I lift one end (two legs) at a time and the ratchet notches are 1 1/4" apart it is not too hard to lift and set the height via eyeball. The legs were laminated up as a single 12+" wide X 3" thick piece and the notches were gang cut on the router table and table saw at the same time. Though the spacing between notches may differ very slightly notch to notch, corresponding notches on all the legs are at identical heights.
A
Alan Schaffter
I originally wanted a motorized lift, but figured too much trouble and expense... and figured I wouldn't be changing the table height that often. I motorized my router lift, does that count? Maybe I'll post pics of that when I get a chance.
D L Ames
D L Ames
Great looking design Alan. I bet that table is solid as a rock and must weigh a ton. What router bit did you use to gang route the legs? It looks like the routing was done at angle.
D L
A
Alan Schaffter
I'm a tinkerer. (Too) many years ago I started out in Mech Eng. at the Naval Academy until low motivation and Mechanics of Materials got in my way. Wish I had stayed the course. (Gotta be a smiley face that's appropriate here)
A
Alan Schaffter
D L
Started with a bull nose bit on the router table, then relieved one side on the table saw with blade set at 45 deg.
woodguy1975
I know what you mean. I have my B.S. and M.S. in ME. Thus my table is motorized. One thing you'll find to be true is the that amount you change the height of your table is directly proportional to the ease that height can be adjusted. It is a big PITA you'll never move it. :D
