After a recommendation by Woodguy1975 I decided to install this system in my new shop. I purchased the "Master Kit" and installed it. I was rather skeptical that the push on fitting would work without leaking air. I was wrong. They do not leak. The system is super easy to install. If you change your mind or make a mistake you can remove the fittings with just a push on the fitting to release it. The kit comes with a cutter that you should use to cut the pipe.
I ran two main lines in my shop from my air compressor that is located in the barn half of my shop. I ran the lines 10' high on the walls and then did a drop drown to about 5' for the air outlets. Each outlet has a bleed valve to bleed off any moisture in the lines. You can put the lines in the wall but I did not put mine inside the wall. I am really please with the system.
Thanks Woodguy1975 for recommending this system.
