Adhesive to attach stained glass to wood
agrieco
anthony
Hi,
Odd request- I have a design made from walnut that I’d like to attach a piece made of stained glass to the front of it. I’d like this to be something that lasts so I’m looking for permanent-ish solutions.
I dont have access to a CNC, nor candidly the patience for manually cutting a recess the piece into the wood itself.
My first thought was some sort of epoxy. Anyone have any other thoughts, or recommendations on an epoxy for such an application?
thanks
jcz
Johnny
I use plumbers goop to secure glass surface to my turkey calls. I think that will be better than epoxy for you. Goop is flexible so it allows for a little movement with the seasons.
@agrieco - clear silicone is is a good option since you can cut it if you are a little sloppy... I think epoxy might be a little rigid or possibly brittle where the silicone is a good "glue" but is somewhat flexible too.
My first thought would be to make a nice frame to attach the piece, but wondering about the shape. Maybe not rectangle?
agrieco
anthony
The stained glass isn’t a regular shape. To give you a sense- here is what we’re dealing with.
KenOfCary
To answer the question, as others have said Silicone glue is the way to go. The wood will move and the glass will not.
I guess I wonder why attach it to a board at all rather than hang it in a window to let the light shine through it. I'm sure there are reasons though, I'm just not thinking of them.
The wife has several small stained glass hangings in windows around the house. They add a lot of color, especially when the sun shines through them.
agrieco
anthony
Best described as sentimental reasons.
