50 cal shell engraving
sawduster
Robert
I am working on a very special commision for a deployed service member on the USS Monterey. I need to find someone who can do some simple engraving on a 50 cal shell . Name on one side , short phrase on the other . Anyone got any suggestions ? i live in Youngsville so the closer the better . BTW Brad was the first one I checked with and he cannot help with this one
TIA
NCTurner
Gary
Hey Bro, if no one here can help, I'd check over on SMC. Surely someone here does scrimshaw work though.
smallboat
smallboat
I'll need to check on how it does with reflective metals.
Should have an answer for you tomorrow.
Glennbear
Glenn
I was going to suggest laser also, I know a firm where I used to live used a laser to engrave dental drill handpieces. :wsmile:
sawduster
Robert
I realize new brass is a reflective metal but this casing is slightly tarnished, has some powder burns at the end and will not be polished in case that matters . I may put a protective coating on it afterwards so it doesn't tarnish further but depending on how the engraving goes , I may not ....still in the creative/advisory stages on that part. The idea is to keep it in it's " spent " stage
the engraving will only be 2 words on each side placed so it can be read while lying horizontally
Phil S
Phil Soper
Morts on West Davie in downtown Raleigh has done excellent work several times
mckenziedrums
Tim
Jewelry shops are the places to check with... they do engravings all the time. I wouldn't go laser with brass, better to do a mechanical engraving.
