I am finally getting some time to work on this. I started it before my daughter was born, she just turned one in October so it should be done by the time she's in kindergarden.
Front:
I was measuring for the lower stretchers and realize that I made the top dovetailed stretchers 3/32" too short in the back which turns the dresser into a slight parallelogram.
Rear dovetail:
Back:
The dustframes can slide out a bit in the notches in the rear so I can fix this with a little bit chisel work on the rear dovetails, but would leave a gap in the "pinboard". It would be covered by the top so isn't an aesthetic problem.
The drawers will have no mechanical slides and I want a pretty tight (almost piston) fit so I worry that the difference will cause them to bind a bit. My question is if it 3/32" is worth the extra work (and messing up my decent fit of the dovetails) or if it probably won't matter.
thanks,
Front:
Rear dovetail:
Back:
thanks,
